十月 1, 2022
Commercial Versus Automotive ESD Integrated Circuit Qualification, Part 1
Integrated circuits intended for automotive applications have higher electrostatic discharge (ESD) qualification requirements than those intended for commercial and consumer electronics. This article is in two parts. Part 1 will discuss why electronic components intended for automotive applications might require more stringent requirements and then review the high-level differences between conventional ESD qualification and automotive qualifications. Part 2, to be in next month’s issue of In Compliance, will give the specific additional requirements for human body model (HBM) and charged device model (CDM) for automotive qualification.
(This article had its origin in a series of blog posts on ESD testing.)
Automobiles have always had electrical circuits. Even before electric headlights and electric starters, magnetos provided electrical pulses to power spark plugs. The amount of electrical circuitry increased steadily over the years, and today, the radio was replaced long ago as the most sophisticated piece of electronics in a vehicle. The rapid expansion in the high-tech electronic content in automobiles has attracted increased interest across a much wider section of the electronics industry than in the past. Integrated circuit suppliers wishing to become suppliers to the automotive industry must become familiar with the qualification requirements for automotive electronics.
The working environment for automotive electronics is much more severe than is common for most consumer applications. Automotive electronics must work in the dead of winter in Minnesota and crossing Death Valley in the summer. The automotive environment is also an electrically noisy environment, with wiring harnesses carrying sensing circuits as well as high current pulses to operate a wide range of motors and accessories. Automotive electronics are often safety critical. It is, therefore, not surprising that the automotive industry has its own set of qualification requirements for electronic components.
Note: This article will summarize the differences between ESD qualification for commercial and automotive integrated circuits. However, this summary should not be a substitute for a thorough reading of the full standards.
Qualification Documents
The qualification requirements for most commercial integrated circuits are dictated by JEDEC’s JESD47 “Stress-Test-Driven Qualification of Integrated Circuits” [1], while automotive integrated circuits are specified by the AEC (Automotive Electronics Council) Q100 standard, “Failure Mechanism Based Stress Test Qualification for Integrated Circuits” [2]. These two documents are very similar in their purpose and methodology. The two documents include the following types of requirements.
  • A list of stress tests required for qualification such as:
    • High Temperature Operation Life
    • Early Life Failure Rate
    • Temperature Humidity Bias
    • Human Body Model (HBM)
    • Charged Device Model (CDM)
  • Specification of the test method to be used for each test
    • JEDEC: mostly JEDEC tests, but some Military
    • AEC: a combination of AEC-specific tests, as well as JEDEC and Military tests
  • Specification of requirements for each test such as:
    • Temperature for test
    • Humidity during test
    • Sample size
    • Number of failed samples allowed
    • Failure criteria
  • When each of the tests is required such as:
    • Design change
    • Change of gate oxide
    • Change of metallization
    • New fabrication site
ESD Requirements
We can now compare the requirements for ESD testing in the JEDEC and AEC qualification documents. Both documents require HBM and CDM testing. Table 1 reproduces the HBM and CDM lines from the device qualifications table from JESD47K, while Table 2 reproduces the HBM and CDM lines from the qualification test methods table of AEC-Q100H. Two columns from the AEC table which are not relevant to this discussion have been eliminated.
Stress Ref. Abbv. Conditions Requirements
# Lots/SS per lot Duration/Accept
Human Body Model JS-001 [3] HBM TA = 25°C 3 units Classification
Charged Device Model JS-002 [4] CDM TA = 25°C 3 units Classification
Table 1: JEDEC requirements for HBM and CDM in JESD47K
Stress ABV Sample
Size/Lot
# of Lots Accept Criteria Test Method Additional Requirements
Human Body Model HBM See Test Method 1 Target:
0 Fails
2KV HBM
(Classification 2 or better)
AEC Q100-002 [5] TEST before and after ESD at room and hot temperature. Device shall be classified according to the maximum withstand voltage level. Device levels <2000V HBM require specific user approval. Refer to Section 1.3.1.
Charged Device Model CDM See Test Method 1 Target:
0 Fails
750V corner pins, 500V all other pins
(Classification C4B or better)
AEC Q100-011 [6] TEST before and after ESD at room and hot temperature. Device shall be classified according to the maximum withstand voltage level. Device levels <750V corner pins and/or <500V all other pins CDM require specific user approval. Refer to Section 1.3.1.
Table 2: AEC requirements for HBM and CDM in Q100H
There are three notable differences between the qualification requirements in the two methods:
  • The test standards differ between JEDEC and AEC for both HBM and CDM
  • The requirements differ
    • JEDEC requires “Classification.”
    • AEC gives specific target levels for both HBM and CDM.
  • JEDEC requires three samples, while AEC says, “See Test Method.”
The difference in the test standards is not as stark as it seems. At the beginning of the AEC Q100-002 for HBM and Q100-011 for CDM are the following statements respectively.
All HBM testing performed on Integrated Circuit Devices to be AEC Q100 qualified shall be compliant to the latest revision of the ANSI/ESDA/JEDEC JS-001 specification, with additional requirements as defined herein.
All CDM ESD testing performed on Integrated Circuit devices to be AEC Q100 qualified shall be per the latest version of the ANSI/ESDA/JEDEC JS‑002 specification with the following clarifications and requirements.
These statements show that the basic test methods for HBM and CDM, JS-001 and JS-002, are the same for JEDEC and AEC. JS-001 and JS-002 are joint standards developed by joint JEDEC and the Electrostatic Discharge Association (ESDA) working groups.
The number of samples at a voltage level is also the same. While JESD47 specifies three samples, JS-001 also specifies three samples. Q100-002 for HBM does not specify the number of samples, so the AEC requirement is governed by the three samples required by JS-001. For CDM, Q100-011 specifies three samples.
The difference in requirements is more substantial. JEDEC lists the requirements as “Classification.” The requirement is, therefore, that all integrated circuit designs must be tested for both HBM and CDM. The actual requirement is set by agreement between the manufacturer of the integrated circuit and the purchaser. For many years it was “common knowledge” that the specification for HBM was 2000 V and that that requirement was being reduced to 1000 V due to the activity of the Industry Council on ESD Targets. This “common knowledge” was, in fact, never true; for commercial product, the ESD levels for both HBM and CDM have always been an agreement between supplier and purchaser.
AEC is much stricter in terms of requirements for HBM and CDM. The basic benchmarks for AEC ESD are an HBM passing level of 2000 V and a CMD passing level of 750 V for corner pins and 500 V for all other pins. As can be seen in Table 2, there are exceptions. Lower levels of ESD robustness can be accepted by the user. The note to see Section 1.3.1 is a requirement for reporting, which reads:
For ESD, it is highly recommended that the passing voltage be specified in the supplier datasheet with a footnote on any pin exceptions. This will allow suppliers to state, e.g., “AEC-Q100 qualified to ESD Classification 2.”
Most of the remaining differences between the JEDEC and AEC ESD requirements are in the additional requirement in Q100-002 for HBM and Q100-011 for CDM.
Part 1 of this article has reviewed why integrated circuits intended for automotive applications might need higher qualification levels and reviewed the documents that specify the qualification requirements for commercial and automotive products. Additionally, it discussed the high-level differences between the ESD requirements for the two market segments. In Part 2, the specific additional requirements for HBM and CDM testing for automotive products will be presented.
  1. JESD47, “Stress-Test-Driven Qualification of Integrated Circuits,” JEDEC Solid State Technology Association.
  2. AEC – Q100 – Rev-H, “Failure Mechanism Based Stress Test Qualification for Integrated Circuits,” Automotive Electronics Council.
  3. ANSI/ESDA/JEDEC JS-001-2017, “For Electrostatic Discharge Sensitivity Testing, Human Body Model (HBM) – Component Level,” EOS/ESD Association and JEDEC Solid State Technology Association.
  4. ANSI/ESDA/JEDEC JS-002-2018, “For Electrostatic Discharge Sensitivity Testing, Charged Device Model (CDM) – Device Level,” EOS/ESD Association and JEDEC Solid State Technology Association.
  5. AEC–Q100-002 REV-E, “Human Body Model Electrostatic Discharge Test,” Automotive Electronics Council.
  6. AEC-Q100-011 Rev-D, “Charged Device Model (CDM) Electrostatic Discharge (ESD) Test,” Automotive Electronics Council.
Robert Ashton
Robert Ashton is the Chief Scientist at Minotaur Labs. He received his BS and PhD degrees in Physics from the University of Rhode Island. After Post-Doctoral positions at Rutgers University and Ohio State University he joined AT&T Bell Laboratories in the field of integrated circuit technology development. He stayed with Bell Laboratories, and its spinoffs Lucent Technologies and Agere Systems for 23 year where he became involved with on chip ESD protection. After leaving Agere Systems he became Director of Technology of White Mountain Labs, an ESD and latch-up test house. He then spent 10 years with ON Semiconductor in their discrete products division, providing and managing application engineering support for transient voltage suppression products. He has published numerous articles on ESD testing of integrated circuits, test structure use in integrated circuits, and CMOS technology development. He has also presented tutorials on ESD, latch-up, and transmission line pulse testing at IEEE and ESDA conferences. Robert is an active member of ESDA working groups for device testing standards and the JEDEC latch-up working group. He has been a regular member of the EOS/ESD Symposium technical program committee. Robert served on the ESDA board of directors from 2011 to 2013 and was business unit manager for advanced topics in 2012 and 2013. He is currently serving as co-chair of the human metal model (HMM) working group.
